DHW too hot in new shower
2 Dec 2018
Hi All.
Had a new shower fitted and the valve is a Bristan Cobalt Recessed Thermostatic Dual Control Shower Valve but the water is too hot even on the lowest setting. Is the valve faulty as I can't see how it would be turned down as its behind tiles now. So I tried to turn down the DHW on the boiler ( which has been rewired and new Honeywell motorised valves but when I go to the boiler to turn the DHW down I do not have a tap symbol to press to turn the water down only a radiator valve.
I would appreciate suggestions please
Is only the shower affected? The boiler won’t control the hot water temperature, this is done by your cylinder thermostat - what’s this set to? Has the immersion been left on?
Sorry, I have a tank which the boiler heats, no thermostat on the cylinder. According to the manual there should be a tap sign on the lcd but only have rad sign
Are you sure the tap sign is relevant? Some instructions on that range cover similar, eg the Ecotec pro have the same instruction manual as some plus models. No thermostat on the cylinder is probably why you’re getting really hot water, as there’s nothing to control the heat, you need a cylinder thermostat ASAP before you scald yourself.
sorry I have just checked and there is a thermostat on the cylinder its set to 60 degrees ( never realised it was there ) is that too hot
Is there anything they can do without wrecking the tiling , tanking etc plus I purchased the Bristan Cobalt Recessed Thermostatic Dual Control Shower Valve so I presume its all my cost :cry:
The shower dial has been mounted in the wrong position. Normally a shower cartridge will have 3 rotations left to right. But the dial will only swing 3/4 of a turn. So it's imperitive you have cold and hot withing the swing. Too far one way and you get very hot and hot.
