    Dismiss Notice
Difference between Single and Double pole MCB
Discussion in 'Electrics UK' started by thebigbadpad, 27 Mar 2012.
  1. thebigbadpad
    thebigbadpad
    27 Aug 2011
    18
    Thanks Received:
    Lancashire
    Country:
    Hello guys
    Just wondering what is the real difference between a single pole MCB and a double pole MCB.
    i dont understand why you would need both live and neutral to trip in a double pole becasue in a single pole if live trips then neutral wont be live anyway.
    Any Help Much Appreciated
    Thanks Guys
    BIGBADPAD
  2. Sponsored Links
  3. ricicle
    ricicle
    14 Sep 2006
    6,343
    Thanks Received:
    382
    Gloucestershire
    Country:
    In a system where none of the outputs from the secondary of a transformer are earthed then both poles need isolation/protection as there will be a PD between either pole and earth.
    Centre tapped secondaries also need DP isolation/protection.
    Using a MCB on an unearthed DC supply will require two pole protection/isolation.
    In an ideal world TT supplies should have DP circuit protection as there can be a PD between N and E. Even other systems would benefit from DP protection/isolation.
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,553
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    Neutral is considered a live conductor.
    Fully disconnecting a circuit is very necessary in TT installations, for instance where neutral usually nowhere near earth.
    Have a read of the BGB 537.1 for clarification.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
