Good afternoon,
I have more questions which I would like some clarification on as I near the start of sorting my bathroom walls prior to tiling.
The first pertains to the plasterboard I am using for the non-wet areas of the walls. This is Lafarge Moisturecheck (i.e. moisture resistant). One side is bright green and the other is a dull light green, I think the bright green is the face side. Do i fit this so that I am tiling onto the face side of the board (i.e. that which has the tapers at the edge).
The second question relates to priming/tanking products. The substrates will be;
Floor - 25mm WBP ply
Shower walls - Knauf aquapanel
Rest of walls - Lafarge moisture check p/b
I am considering priming everything with a decent primer before tiling, however am wondering whether applying tanking to the shower walls would be better. Any views?
For the record, I intend to use BAL adhesives and grout.
Thanks again for the advice.
