Hi all,
I am getting myself a bit confused over the correct products to use in a new bathroom. It will have dry lined walls, be 1.7m square and have a toilet, basin and bath with shower over.
My plan was to use knauf aquapanel with an aquaseal tanking kit, then tiles around the bath and shower and basin area, then knauf moisture panel on the remaining walls which will be taped, jointed and then painted. Does this sound ok?
I know the aqupanel joints need taping with waterproof tape, but how do i deal with the joint between the aquapanel and the moisture panel, bearing in mind the moisture panel is tapered and the aquapanel square edged? Do i just need to use normal tape and jointing plaster?
Also, for the tiles, do i just use ordinary adhesive and then a waterproof grout and a normal edging strip? They are just normal ceramic tiles
Thanks,
Jay
Thanks,
Jay
