There is no such thing as a digital aerial. However in some areas to get all the digital signals in the band they are more spread out than with analogue so you may need a wide band aerial. However for the same gain as a narrow band aerial they are physical bigger so have more air resistance so need bigger mounting poles and brackets so only use if required.
As to Hard Drives and DVD recorders because of digital there are many for sale very cheap without the digital encoders. These can still be used with a converter box but take a little more to set the record.
As analogue stops the auto correct function will stop working and you will need to be more careful on setting times. But at half price I felt well worth while.
Having first had a DVD recorder only then changed it for DVD with Hard Drive the latter was much better as it allowed one to trim off advert at start and finish and skip adverts in the recorded program before writing onto DVD so 40 mins is reduced to 30 mins so more on DVD.
With just DVD I used all re-writeable DVD's as write only seemed to fail a lot. However with combined unit I use write only if one does fail I can always do it again.
Having said that my Sky+ is far far easier to program and much less likely to ever miss a record. Although the ability to skip adverts is harder to do than with Philips Hard Drive. Also not as easy to skip back when you miss something or to after watching decide you would like to keep a hard copy.
The Hard Drive / DVD recorder will keep the last 6 hours of watching very handy when you fall asleep in front of the set.
I am sure there is a way to get Sky+ to do the same but with Hard Drive it is always set to Sky so it records 6 hours back even if I change channel but with Sky+ as soon as I change channel I lose what was backed up.
I have both so have best of both but if asked to have either Sky+ or Hard Drive / DVD recorder without freeview it would be latter as the units will not last as long as the DVD's it burns and I also use it to burn DVD's from web cam and digital camera.
Do I think it is worth paying double to get built in Freeview no I don't mine cost less than £100 new.
Problems yes if I record at lowest quality i.e. 8 hours on 1 DVD then sometimes it fails. Recording with 4 hours for 1 DVD I have had no problems.
On the odd time it has crashed and I have needed to unplug and re-boot but this has only happened on odd time.
I also have free to sat boxes and these don't have as good a program guide as Sky boxes but can be used for other satellites and allow you to remove the programs you don't want so no need to wade through all the programs you can't or don't want to watch. If your not going to pay for a Sky package then get a Free to sat box now Channel 5 etc. are no longer encrypted so advantage of Sky box is only the EPG but weigh that against having to wade through all the rubbish programs I think free to sat is better option.
With the 5 sat boxes I have used every one has plus and minus points but all free to sat boxes seem to be more sensitive than the Sky boxes and some also have connections for rotators so box also controls direction of dish and what satellite it points to this is not available on Sky boxes.
Hope that helps you make up your mind. Free to sat in Lidl and
Screwfix around the £40 as you go to rotators etc the sky's the limit.
