I have had a good look through earlier postings but I'm still not totally clear. We have a MK dimmer switch (2 gang one way) linked to standard ceiling lamp and wall lights. We recently bought a new ceiling lamp, 5 * 20W bulbs, but it is low voltage with a transformer enclosed in the metal part that fixes to the celing. The light's instructions state that this can't be dimmed. However, the chap in the local wholesaler's seems to know his stuff and suggested that simply bypassing the transformer in the lamp with a new dimmable low voltage transformer would be ok. This seemed fine and I was happy to do this until I looked at the instructions for my MK dimmer which states that it's not suitable for low voltage fitting. Returning to the wholesaler, he explained alot of incomprehensable technical reasonings but basically said that they were simply covering their backs and that it would work fine with no problems (nor dangers!). But, if I wanted to be 100% sure I could buy the level up MK Dimmer for £45 + VAT and throw the old £30 dimmer in the bin!
Can anyone advise if a standard (MK) dimmer would be ok to use with my new fitting provided that I connect the dimmable transformer or will I ALSO have to fork out for a new low voltage dimmer? If it is the latter, am I allowed to buy a cheaper low voltage dimmer and put these innards into the MK fitting (provided that they fit, obviously)?
Hoping someone can help, Dafulang
