Dimmer Switch Swapping
  • Thread starter Thread starter Leitchy
  • Start date Start date
L
Leitchy
Hello all o/
I am attempting to refit an old dimmer switch with a new normal switch. The dimmer has 2 knobs on it, one for each pendant light in the living room. Upon buying the new switch I find that things are not quite the same, and the wires going into the dimmer switch are all red!!!!
So instead of blowing oneself up, I am requesting a bit of help off this forum.
I've taken a picture of the light switch below.
http://www.leitch-designs.co.uk/switch.JPG
Sorry for the quality, but I think you get the idea of it.
The switch I baught was a "LightSwitch Double 2Way 6ax" so is this suitable?
Thankyou, please post if you have any more questions
A small update which I never included. The connections on the dimmer plate are labelled "C", "L1" and "L2". The connections on the new switch are "Common", "1 Way" and "2 Way".
The wire you see not connected in the picture, is one that seemingly 'fell out' when i removed the face plate from the wall. So I am not sure where that would go again.
Its a bit blurred but I believe that you will do the following:
Iguess your new switch has two sets of terminals marked C. L1 and L2, yes?
You have a red wire that is linked between the two terminals marked 'C' on your dimmer, yes?
Coonect the red wires above onto the thw two C terms on your new switch.
You are the n left with two red wires still on the dimmer.
Put one into the position marked L1 on yr new switchj and the other into the other L1.
Thats it.
I assume the new one is not a metal switch? if it is you need to earth it
Just got yr updateed post
C = common
L1 = One way
L2 = two way
Swop wires one for one per above.
Turn power off first!
Thankyou, I have since uploaded a better photo for clarification. The wire that is not connected to anything, what will that be?
The wire which has come loose is the feed to the switch, and should be connected to one of the 'C' terminals, with the short link linking to the other 'C' terminal
You have a red wire connected ibetween the two C terminals. The loose wire will also go into one of the C terminals.
Ok thanks a lot, time to go blow myself up :D
Will let you know how it goes once I start the computer up again!!!
Me again. The switch worked perfectly so thankyou all that replied for your time, now the wife will leave me alone!
