I bought a metalic double dimmer switch from Homebase for an electrician to install but he said it was not suitable for the load (6 low voltage lights on 1 switch and 7 on the other). He installed a different dimmer switch.
The trouble is the lights don't dim all the way down and the plastic covered plate is EXTREMELY hot. To the point that you would burn yourself if you touched the plate for more than 2 seconds.
It all looks (and sounds) extremely dodgy.
Has this happened to anyone else before? Do you get different dimmers for different loads? I didn't notice any in Homebase but can't say I really looked. I suspect the transformers are not dimmable as one of the downstairs lights flickers if dimmed.
Will the hot plate cause any damage to the original wiring?
