we have a dimmer switch of the type where you push the switch on and then rotate it
its rated at 600-1000W
it controls 5 halogen GU50 in the bathroom = 250W
recently one of the bulbs went and then the dimmer part wouldnt work
the dimmer switch was replaced
another bulb went and subsequently also affected the dimmer switch dimming facility
the bulbs i can see were faulty and am happy to change them
the dimmer is something different
what could be the reason for this if the two incidents...bulb failure/dimmer failure are connected
at present i just use the on off part of the switch..its outside the bathroom...and wont replace it till i can understand what may be the cause of failure
