I have a dimmer on a two way switching format with a rocker at the other end. One of the dimmer channels has burnt out. A friend has suggested that this is a problem with two way dimmer systems that the charge is always running across the coil and therefore burns out quickly. Can anyone tell me if this is the case and if there is a solution to it? (apart from not using dimmers!!)
If this is the case then why do we get 2 way dimmers?
btw the dimmer is not overloaded so that shouldn;t be the cause of the burn out.
Thanks guys
Thanks guys
