Dimplex storage heater not working
6 Nov 2016
I have a Dimplex XL18N (S/N: 002440/01 WW) storage heater which is not working (and never has since i moved into the property). It's always completely cold, despite setting the input to the highest level.
I've tried re-connecting it to the electricity supply with a new double pole switch.
I've also tried resetting it - however i couldn't find an obvious reset button or anything which resembles what online info has suggested should be there. Between the 3 white rolls on the right and the single white roll on the left is a curved metal clip. This was up, so not making contact with the metal piece below, so i pushed that back down. The heater is still not functioning though.
Does anybody have any ideas?
Have you checked there is power to the DP switch?
Regards,
DS
Regards,
DS
Yeah, that's why i installed a new one which has a power indicator light on it so i'd know for sure it's actually getting power. It comes on like it should during the Economy 7 hours.
The overheat reset is that white plastic button hiding below the white wire. If it trips again the input stat is faulty. Looking at the amount of rust, a new heater won't be a bad option. If you do just replace the input stat, replace the cutout as well, they usually come as a kit.
Great, thank you. I've just pressed that button, so hopefully i'll see later that it worked. If i do end up replacing the input stat/cut out, presumably this is fine?
I'm not sure that is the correct one, the XL18N model has been around for many years and the internals have changed many times. I think there is a conversion kit for fitting newer stats. Here is a better place to look, phone the company if you are unsure, letting them know the model, serial and series codes.
I missed this before, looking at the photo the stat is now busted and needs to be replaced.
Did i bust it by pushing the metal clip?
I've emailed that site and Dimplex about the correct part. Thanks.
Yes, it's not supposed to be buckled like that! It's a finely calibrated component.
Ha, ok, that makes sense. Hopefully i'll get a quick response so i can purchase and fit a new one. Thanks for the help.
