Disabling Sensor..
20 Oct 2006
West Midlands
Hi, I ve got a Guardall Apollo 15 Sensor in the corner of the room I want to decorate...I need to temporary remove it but still have the rest of the alarm system working...do I need to connect any of the wires?....thanks for any help...
Wires I have are :- Black,Red,Green,Yellow,Blue and White.
Don't short the + the 0v .......you will need to short the alarm pair and the tamper pair together for your alarm to work , can you just unscrew the pir and move it out of the way while you decorate ....
Cheers...I need to remove it because I'm fitting coving....
Don't forget that opening the cover will cause a tamper (unless you're in engineers/programming mode). You should be able to stop the noise with your code. Then, once you've twisted the tamper pair, you can reset the panel. You may need to extend the cable if you're fitting coving...
