Hi All,
Have done 2 ceilings before now, with no problems. I think I may have bitten off my than I can chew with the current ceiling....
6x3 metre ceiling covered in stipple, with a 3m x 1ft (6mm deep) recess where I removed the arch wall. 6mm due to the fact that someone had presumably skimmed/stippled after the arch went up.
I knocked off all high points of stipple. Scrim taped over recess. PVA'd (4 parts water, 1 part PVA) and left to dry. Then PVA (50/50) again, and whilst still wet, started skimming. Room temperature was about 18-20C. Got half way across the room, then panicked as the first area had pretty much set (I had planned to trowel over lines/holes/imperfections). I kept hearing popping noises and holes appeared all over the shop. I spent the next hour trying to rectify the dips/holes, etc., so have basically screwed it up.
It looks pretty awful. When I did an evening plasterers course, they told you to ensure your first coat had no holes/lines, etc as they would show up in the second coat. We were also told to put the second coat on as soon as the first coat started to set - I had no time to do this. I am now left with a half covered ceiling with only the one coat, and it looks sh1te.
Looking back, I think I made the following mistakes:
1. Room temperature should've been lower.
2. Should have ensured no lines/holes/imperfections as I went along (I was just slapping it on like I was told to do)
3. Over trowelled it
4. Used water (in panic) when trowelling after it had pretty much set
What are my options now? Do I have to PVA in between coats if I have left it to dry? Can I rescue this with a second coat? What's the best way of merging the two halves together (should I apply 1st coat to the other half first?).
Or, should I just rip the ceiling down and put new plasterboard up and skim again?
If you've read this far, I salute you!
Thanks in advance,
TEk
PS - my neck hurts
Thanks in advance,
TEk
PS - my neck hurts
