Hi all. New here so hope I've posted in right place.
I have a 2014 Dacia Sandero 1.5 Diesel.
The airbag light was staying on and someone suggested disconnecting the battery as this can reset it. So I disconnected the battery, but I only disconnected the positive. I then reconnected it, and now the car won't start. I turn the ignition on, and all powers up as normal, I then turn the key to start the engine. It turns over as normal but won't fire up. No coughs or splutters, no nothing.
I didn't cause and shorts when I disconnected the positive. The only sparks were the very small sparks between the positive terminal and the cable as I separated them, and again when I reconnected them.
Any help will be gratefully received. TIA.
