My Hygina AHY8101 turns on tries to start a cycle makes a bit of a werring noise, open it up and its still dry inside. I recon its not getting any water, its very diffcult to get the thing out as they have fitted it and then fitted the flooring round it, so I will need to pull the laminate up to be able to pull it out.
Before I do this just in case it is water related how can I turn the water feed off to the d/w ? I can see two feeds under the sink, they have blue switches on both laying horizontal at the moment, do I just push them up to the vertical position ?
Secondly if it is getting water and the pump or some other bit has gone, would I actually see the d/w fill with water ?
