Diverter valve ferroli optimax c31
25 Mar 2021
What causes the diverter valve to operate? I have replaced mine a couple of times, but the rads still getting warm when I draw hot water. I assume the diverter valve is not operating. But what triggers it to shut off?. I'm looking for a problem earlier on in the process I guess?
The motor operates the valve, so maybe that's not moving properly?
Makes sense, but what energises the motor? How does the boiler know the hot water is being called for?
So previously I changed the flow sensor and didnt make a good job of it. I either misfitted it or it was faulty part. Basically it wasnt sensensing any flow, but the result was the ignitors were not firing. When I put the old one back it started firing again. So my conclusion was the flow sensor told the ignitors they had to fire. But I didnt know if the also told the diverter valve to switch
