- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,438
- Country
If I said to you "I've stood on the plug on this TV, and broken it; can you change it?" would you say yes? There isn't anything more to this job than that; you're putting somewhere between two and three wires into holes and turning screws so as to trap themconsiderations of personal safety
Of the two options offered I would opt for the "disable the circuit by putting the live and neutral cores into the earth bus bar in the CU" route, as the cable will likely be a 6 to 10mm cross sectional area and wiring a socket onto the end of it would be a little tricky.
If you're patient and willing to mess about a bit getting things bent into the right shape in preparation then putting a socket on is possible
It shouldn't, for the logical reason that:putting my hands anywhere near the CU does feel like a step up
There is a master switch on the CU that when flipped makes everything inside it dead. Forget to flip that and everything inside it, as well as the end of the cable you're planning on working on, could make you dead instead .. there isn't really any difference between the near end and the far end of the cable in terms of danger (aside from touching the busbar in a full RCBO setup), but there is a heck of a lot more room to work inside the CU than inside a back box
If you do go for a socket, get the deepest back box you can get. If you struggle to get the strands of the wire cores into the socket terminals, clip one or two of the strands off at the sheathing. Do any bends necessary before you do this
