Do I need a sheet under my underlay and laminate floor?
15 May 2013
Hi all,
I have just had my floor screeded on a new extension. Underneath the screed is vapour barrier sheet and 100mm insulation, underneath that is 150mm of concrete and a dpm sheet. I'm nearing the phase of putting down laminate floor and in the past I've just done foam underlay then laminate floor. When reading up on this recently Internet seems to say put a plastic sheet then foam underlay then laminate flooring. What I'm wondering is how important is the sheet?
Thanks for your advice
Residual damp.
Plastic stops that.
Condensation can form in concrete.
Warranty from floor manufacturer.
I've used cheap £1 sheets in the past. Not the stuff recommended but what I had..
Up to you if you don't use but good practice to follow spec
