- Joined
- 27 Jan 2008
- Messages
- 29,846
- Reaction score
- 3,709
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The fan and rear element runs and the grill turns on so it is cooking from both sides, so only need to turn food once, works well with bacon.You can't see what's going on with closed door grilling. I actually bought a standalone wall mounted electric grill because I like to see what's going on....
I think the selector on our oven has 12 options, there are elements at side, top and rear so it is a bit like the old Rayburn oven where you could change the damper setting to control how the oven heated, the problem is cook books.
Mrs Beaton would have had the damper setting, however it seems it been rewritten, as it would not have had Gas Mk setting as gas ovens did not exist when she wrote it. It seems the Gas Mk settings have replaced the damper settings, so only the cook book which comes with oven is much good.
I do realise there are so built in steam ovens now which clearly do more than my stand alone, but the 13 amp limit UK, or 16 amp limit Europe means the use of two sets of elements at the same time can't be done with the current limits, only with a stand alone with 32 amp can we have these options.
