The rafters are nailed to the ledger plate using 90mm collated nails. I thought this was common practice - Is that OK
I went a bit OTT on the size of the ledger board but as it wont be seen i am not too fussed about it.
I need to install a small fillet above the ledger board for the top tile batten to fit to. I realized the rafter calculator i used allowed for a fillet rather than the tops of the rafters hitting the wall after i had made all of the cuts!!
I was considering adding a smaller restraint strap mid door span as the door is 2.5m wide. I will pick some smaller depth ones up this week
Last rafter on the right is spaced differently as it has a cavity wall between it and the next rafter. Its only fixed temporarily to allow me to build the wall up then i will add a further rafter in between the 2 to close off against the wall.
Ridge and jack rafters are now in also just leaving the valley
