I have been trying to troubleshoot my mum's bath/shower valve.
www.diynot.com
Today, I used a slotted screwdriver to close the two isolating valves.
I pulled the thermostatic cartridge out and noticed that the hot water isolating valve was still letting water past (running out of the housing for the the cartridge). Out of interest, I opened the isolating valve fully, and then noticed that the amount of water coming out of the housing was pretty much exactly the same.
Can those isolating valves fail in a frozen semi open state?
I am used to them spitting water out of the front and not fully closing, but I have never encountered one that turns but doesn't open fully.
I will add that I have thus far been unable to remove the filter for the hot water on the bath/shower valve, but given that the hot water isolating valve does not close leads me to assume that it is at fault
Crosswater 3 way thermostatic valve- 90 mins to run a bath
Hi all, my mum has the same crosswater thermostatic valve that I have. Mine is mains water pressure, hers is on a gravity fed system. Over time, the pressure on hers has been dropping off (substantially). It looks like the following (but with slightly different tap heads)...
www.diynot.com
