Do you have to hardwire alarms?
15 Apr 2010
Kent
I recently purchased an enforcer plus and would like to be able to have the option to move the unit around. Is it possible to wire a fused cable and plug to the unit?
Yes, if you want someone to switch it off or unplug it to use the hoover, something WILL happen, it always does when the job is not done correctly.
Thanks, thats a good point but the plug will be in an eave so no hoover's & won't be unplugged. Other than that any reason why I can't put a plug onit to make this wireless unit more portable?
I know someone who has their alarm plugged into a regular wall socket. Doesn't cause any problems whatsoever, but they have Tipexed "A" onto the plug so that you don't mess with it. Don't forget that if you unplug it, you'll know when you come to set it so that you can plug it in again. You should probably put a smaller fuse into the plug than 13A, but who does that in real life?
Thanks Paul, I'll definitely label the plug and go for the smaller fuse cheers.
