    Dismiss Notice
Do you need subbase/sub base and sand under a screed kitchen floor?
Discussion in 'Building' started by DIYRuthie, 1 Sep 2020.
  1. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Quick update, and further question. Can fibre screed be used as mot 1 sub base?
    As expected BC will not sign off the floor, so it looks like we will be diy ing it. It's a reminder of why I have been doing most things on the house the last 6 years. To reduce the amount of waste, and need for a skip, we were wondering if we could remove the fibre screed, break it up. Dig down enough, compact it at the bottom and work our way up with sand, cement, dpc, insulation etc.
    Also, anyone know what the shallowest solid floor would be, to reduce the amount of digging.
    Cheers
  2. Sponsored Links
  3. 23vc
    23vc
    17 Apr 2015
    2,152
    Thanks Received:
    313
    Warwickshire
    Country:
    Trouble is the screed is a pretty sandy mix anyway so there won’t be much left of it if you break it up. If it’s only a 65mm ish screed it shouldn’t be too massive to dispose of? Depending on room size
    Only other option is ask Bc if you can treat the screed as a base and pour a slab on top, unlikely but could ask
  4. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    That's OK, we'll get the proper stuff in!! The floor is level with a suspended timber floor at the moment, so we will be aiming to get the same level and putting concrete on top would make it too tall. We may treat ourselves to underfloor heating if we do it ourselves.
  5. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Any idea what the easiest/shallowest solid floor would be? Or alternative construction? As we will be starting from scratch, we have a choice.
  6. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,462
    Thanks Received:
    666
    Durham
    Country:
    Easiest solid floor is the one in the Approved Docs- 100mm hardcore, 50mm sand, DPM, 100mm insulation, 100mm concrete. Depending on how good you are with concrete (and what the planned floor covering is) maybe allow 25mm for screed or 10mm for SLC. UFH you'd usually need a thicker screed.
    • Thanks Thanks x 1
  7. Nige F
    Nige F
    28 Jun 2005
    20,642
    Thanks Received:
    1,613
    Country:
    Have you allowed for air venting pipes through the solid floor to the suspended one ?
  8. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Yes, the builder put some in but they were away from the brick, so the screeder went over them! We will make sure we do as the previous owner didn't and we have damp issues in the hall. Not sure how to connect them to the airbrick, but will have a look at my DIY Manual book!!
  9. Sponsored Links
  10. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Thanks, will have look at the approved docs.. Which 'Part' is the the doc?
  11. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Dad daughter time this weekend, sorting out a leaking boss connector. Then will be smashing up the floor next weekend!
  12. DIYRuthie
    DIYRuthie
    1 Sep 2020
    16
    Thanks Received:
    Country:
    Does the Hardcore have to be MOT Type 1?
    We smashed the floor up this weekend, and will be digging down to the required depth for this.
    The DPM had pierced under the insulation, and the floor was all uneven. We are so glad we caught this now!
    • Like Like x 1
  13. Keithmac
    Keithmac
    10 Oct 2017
    1,578
    Thanks Received:
    249
    Country:
    Pretty poor show from the builder, at least it'll be done properly this time!.
    • Like Like x 1
  14. Notch7
    Notch7
    15 Sep 2017
    19,674
    Thanks Received:
    1,373
    Sussex
    Country:
    You made the right decision, at least when you tile you wont have any worries about it being solid
    • Like Like x 1
  15. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,462
    Thanks Received:
    666
    Durham
    Country:
    Doesn't have to be but for one floor in one room its not worth risking rubble, for 100 tons the sums would change.
    And glad you've bitten the bullet & decided to do it properly, that bodge floor would have been a nightmare in a few years
Loading...
Share This Page
