Hi all
I've been in my house a few years now and always wondered about the legitimacy of a certain aspect of its wiring, even though there have been no issues as such to speak of while I've been here.
Part of it had been disconnected when I moved in, and I'm assuming it would be a bad idea to connect it back up as I suspect it's a potential bodge, but I wanted to describe it and ask people who know better.
The circuit from my consumer unit that feeds my immersion heater (from a 32amp MCB), has in the past had a double socket added to it in the utility room next to the water tank.
The washing machine and dryer are plugged into this, and we've never had any issues. The immersion heater is never used.
I seem to recall asking the sparkie when we had other work done if this was correct, or if the immersion should have that circuit all to itself and I vaguely recall he said it's not the normal way of doing it but should not pose a problem. I may be remembering incorrectly here but it was all deemed to be fine when we bought the house anyway.
I'm not overly worried about that aspect of it, but my question concerns an apparent previous power feed from this to the shed.
The double socket on this circuit is a spur (I presume as it has a single cable into it) with 2.5mm twin/earth, but it has a disconnected cable from the socket continuing to the shed.
The cable is armoured stuff (black outer rubber insulation then lots of tough steel wires wrapped around an insulated inner sleeve which has black, brown, & grey wires within), and is pretty substantial. This goes down into the concrete path (not sure how deep) for about a metre distance from the house to the shed, then comes up inside the shed to some sockets.
There is a neon spur switch inline inside the utility room, but as I say this feed to the shed is disconnected anyway. Not sure why exactly.
Does this sound like a bodged way of feeding power to the shed? It might be one thing having a double socket in the house on the same circuit as the unused immersion tank, but is it safe that this spur/socket also feeds a socket in the shed or has it likely been disconnected due to being dangerous?
It'd be handy to get power out in the shed and it's obviously had it in the past but I don't want to risk anything if it shouldn't be like this of course. If people end up saying it's actually ok I'll get it checked anyway, but I suspect the answer is "don't hook this up without x y z!".
Sorry that goes on a bit - Appreciate any useful input thanks.
Cheers!
Jim
Cheers!
Jim
