Did you find a solution to this?? I have just fitted the Quadro vertical radiator from B&Q and have got very similar symptons.
Im not sure if my system is a 'one pipe' but the radiators do seem to heat up in a sequence.
I installed the radiator in replacement of a regular horizontal one, and have a combi boiler.
Once the heating is turned on all the radiators in the flat are red hot within 10 mins.
The pipes in and out of the new vertical radiator took a long time to heat up but eventually were red hot. But the radiator itself remained stone cold on the whole with only a couple of very luke warm patches.
The radiator was installed and the inlet to the boiler was opened whilst the rad was bled. Pressure now showing on the boiler is 1.8 bar which according to the manual is within good limit.
It leaves me wondering the same questions as to wether the radiator is fitted upside down (even though it has brackets to hang it up either way) I opened the bleed valve which I fitted up at the top end and cold water gushed out.
Anyone help PLEASE!!!!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
