I'm having the kitchen renovated. In one corner is a hugely ugly pipe (maybe 2 pipes) that has been boxed in with some equally ugly tiles. Ideally, I want a wall unit fitted right in that corner but the pipe and boxing in is in the way.
The stop cock is right under the plumbing for the kitchen sink (albeit below the floor). It seems that the mains supply goes through the stop cock, and then immediately up the ugly pipe to the bathroom. The picture tries to show this: the dark blue line is my understanding of where the mains supply runs; the light blue line shows the water supply for the downstairs tap and the outside tap. To be clear: the pipe represented by the light blue line passes in front of the ugly pipe represented by the dark blue line. The light-blue-line pipe is not teed of the dark-blue-line pipe.
My question is: can I shortcut the ugly pipe by simply connecting the downstairs tap plumbing directly to the mains pipe just after it leaves the stop cock? My proposal is shown in a gold dash line. If so, I could ask someone to cap off the ugly pipe in the ceiling void and remove it from the wall, making the kitchen fit a lot easier. However, I suspect that the answer is "no" because it would mean water going the other way through some of the plumbing.
The reason it is fairly urgent is shown in the second picture. If I can remove the pipe then I can tear out the ugly boxing in so the plasterer can finish off tomorrow. If, however, my proposal is nonsense then I need to box that ugly pipe back in again first thing in the morning before the plasterer starts. I have absolutely no idea what is happening with the pipes that run horizontally through the wall here (and I don't know what the rusty pipe in the wall on the right hand side in the first picture is, either)
