Does it matter if I use 4" or 5" feather edge for cladding?
9 Jul 2008
Hi all,
Supply issues are driving me nuts.
I'm going to be cladding a small garden building in treated featheredge. Does it matter whether I use 4" (100mm) or 5" (125mm) boards?
27 Feb 2017
Essexshire
Well it wouldn’t bother me. If I could only get one size, that’s what I’d use.
25 Apr 2016
Do remember that the narrower the board the more you will need. A 4" board will only have 3" cover when you allow for the overlap.
9 Jul 2008
Thanks guys. Still works out marginally cheaper for me to use more of the thinner boards - not enough to make much of a difference.
My main interest is doing it the best way for longevity. But if board width doesn't affect that, then I'll use the thinner boards because it's proving harder to source the wider boards.
25 Apr 2016
Ok. Just remember - thick edge down, only nail inch and quarter up from bottom edge and overlap by no more than an inch and no less than three quarters of an inch.
The board above will hold the thin edge in place and the boards won't bulge or split with the boards swelling or shrinking with the weather.
That way if you have to replace a board you only damage the one you are replacing.
28 Jul 2009
Devon
I would go for 6 inch actually from past experience - a lot easier to work with and you don't need so many lengths.
11 Feb 2016
monmouthshire
With the timber shortages as they are at the mo I think peeps have to make do with what they can get, or wait goodness knows how long
28 Jul 2009
Devon
There be plenty down here in Devon and the shortage bits are no good anyway, he likely needs long bits.
12 Jul 2004
Surrey
others may disagree but feather edge and longevity for a shed do not come to mind
if you are going the whole hog with insulation breathable membrane air gap etc why not go for txg shiplap ??
