A condensing boiler keeps the flue gases cool enough so the water in the gas condenses, to do that it can use two methods, one is modulate which means turning down output, the other is to use a mark/space ratio, the space getting longer and the mark getting shorter and it does this once the boiler is already at minium output.
This is why it is so important for the boiler to be correctly sized, my home is three story and has a 20 kW boiler, I hear the boiler turning on/off so clearly it is large enough, which asks the question why so many homes have 35 kW boilers?
But what we are looking at is not the maximum output, but the minium output, and some makes of 35 kW boilers can modulate to a lower output to other makes with a 25 kW boiler.
Before the hour was taken off, I was using a 2 kW oil filled radiator to heat our main room which was ample, but electric cost more than oil, and once we went the UTC my solar was not enough to run the oil filled radiator, so switched to central heating, but the point is at the start of the season 2 kW was enough.
Hardly any boiler will turn down that low, so it has to use a mark/space ratio. But when using analogue control it turns back on at minium output, but with digital (on/off) it turns back on in the main at maximum output.
There is no reason why a boiler should not be programmed to turn back on at minium, and it is possible today some boilers will, restart at minium. If I was programming it I would do just that, but I am not a heating and ventilation engineer, I wrote programs to run concrete batching plants, candle making plants, etc, but not a boiler, which likely uses a PIC rather than a PLC and I was never very good writing PIC programs.
