Does thermostat in coldest area make sense?
I think I have said often enough that I don't think that's correct.
OK a bit of a generalisation, using the likes of Wiser, there is no real reason to have a wall thermostat, the TRV can do it all.
The USA version of Nest uses sensors in many rooms linked to the main thermostat, and does not need any TRVs to be linked, likely as in the USA they use hot air not water to move heat around the house.
There is no reason why one should not have a wall thermostat in every room, so the wall thermostat controls minium temperature and the TRV maximum temperature, but in the main we compromise, I call it near enough engineering, and the main point is the boiler need to modulate so on/off control is not really very good.
Well, one or the other. Or none of those.
I know that some bespoke/odd properties need bespoke heating controls but the vast majority just don't.
Room stat to suit the boiler and manual TRV's is all I ever fit. And generally see fitted to be honest.
We should design the system to suit the home and occupants, the idea of one design suits all, is clearly berrying ones head in the sand.
The main point, is with a condensing modulating boiler, the control should be analogue, as to if that is an OpenTherm wall thermostat or a TRV is really not important, as long as the device does not cause the boiler to turn on/off too often.
Of course, but a fairly standard home with similar use is by far the most common. They'll likely have different heat loss characteristics, maybe a shower or bath difference, including how many, Maybe more or less rooms, but all in all it is still a pretty standard heating/hot water requirement. And yes, there are outliers that need a different approach, but that isn't the norm.
Like electrical design, there is no one size fits all. But, in the main, most will be similar as in one consumer unit with however many circuits protected by similar means. Not exactly the same, but near enough as makes no real difference. But then you might come across some bespoke castle that needs a bespoke solution. But they will be few and far between.
