OK a bit of a generalisation, using the likes of Wiser, there is no real reason to have a wall thermostat, the TRV can do it all.
The USA version of Nest uses sensors in many rooms linked to the main thermostat, and does not need any TRVs to be linked, likely as in the USA they use hot air not water to move heat around the house.
There is no reason why one should not have a wall thermostat in every room, so the wall thermostat controls minium temperature and the TRV maximum temperature, but in the main we compromise, I call it near enough engineering, and the main point is the boiler need to modulate so on/off control is not really very good.
We should design the system to suit the home and occupants, the idea of one design suits all, is clearly berrying ones head in the sand.
The main point, is with a condensing modulating boiler, the control should be analogue, as to if that is an OpenTherm wall thermostat or a TRV is really not important, as long as the device does not cause the boiler to turn on/off too often.
