You seemed to make such a definite statement there that I thought you'd found something that forbade the use of 20A switches on a RFC.it is, strictly speaking, not compliant with BS7671
What relevant requirements? Other than the relaxation of the requirement as regards OPD rating vs cable CCC, a ring final is just 'a circuit', so I would presume that anything that can be connected to any other circuit can also be connected to a ring final circuit..... i.e. accessories to BS 1363 are deemed to be suitable, use anything else and you have to check that all the relevant requirements are met .... and the item is in fact suitable for connection to a ring final.
On the basis of what criteria is one meant to 'check' that? There is only the one regulation in BS7671 which relates to ring final circuits and, as we have said, that mentions nothing as being 'suitable for connection' other than BS1363 accessories.... and the item is in fact suitable for connection to a ring final.
As I said, I was merely reflecting the interpretation which, as far as I am aware, is the one that has been universally expressed by everyone who has commented on the issue in this forum - even though, as you have said, that means that they are assuming the presence of the word "only" which does not actually appear in the regulation.You seemed to make such a definite statement there that I thought you'd found something that forbade the use of 20A switches on a RFC.
But it isn't normative, so isn't really a 'regulation'. It simply gives permission for those accessories to be used in a RFC. Your 2 immersion heaters would need to be suitably located on the RFC, among other requirements.If so, then anything could be supplied through a ring circuit and the regulation, as far as BS1363 is concerned, is virtually meaningless.
No idea.What relevant requirements?
It also mentions nothing as being unsuitable.that mentions nothing as being 'suitable for connection' other than BS1363 accessories
That's what I have been saying. Whatever one may think about the authors of BS7671, they must surely have had some reason for bringing BS1363 accessories into that regulation.If so, then anything could be supplied through a ring circuit and the regulation, as far as BS1363 is concerned, is virtually meaningless.
Well, I have an idea ... in terms of BS7671, there are no stated "relevant requirements" of things to be connected to a ring final circuit, other than the one statement that BS1363 accessories may be so connected.No idea.
Exactly - BS7671 is silent as to what is suitable or unsuitable, other than that one mention of BS1363 accessories ... so what did you have in mind when you said that people should 'check' that what they wanted to connect to a ring final circuit was 'suitable'??It also mentions nothing as being unsuitable.
If it was the intention of the writers of BS7671 that only accessories to BS1363 may be supplied by a ring final, they could very easily have added the word "only". However, they didn't, and haven't.
You are looking at it from the wrong direction.It also mentions nothing as being unsuitable.
In what sense is it any less normative than anything else in the body of the Standard?But it isn't normative, so isn't really a 'regulation'.
The word "only" is superfluous.
Perhaps the authors intended that the implied "only" would come before "through", thereby prohibiting the use of BS1363 accessories on radials?Accessories to BS1363 may be supplied through a ring final circuit
Less complete, I would say, since the notice would then be silent as to whether or not food not bought in the cafe could also be eaten in the cafe.I was thinking about the word "only" in a cafe today. There was a notice stating "Only food bought in this cafe may be eaten in the cafe". Would the meaning be the same if "Only" were deleted?
I doubt that anyone does. However, it is certainly possible to interpret what is "actually written" in a way that would mean that such things were prohibited, even if that were not the intention. That wouldn't be unique. There are several regs in BS7671 which "actually say" (or imply, or don't say) things that I find it hard to believe was really the intention of the authors.Does anyone think it was the intention of the authors to prohibit the use of JBs, DP switches, etc on RFCs?
That's correct. It doesn't say that though, it says "may", which means it is permitted."Accessories to BS1363 shall be supplied through a ring final circuit", I think that would probably mean that it was not permissible for such accessories to be supplied through any other type of circuit, wouldn't it?
That seemed to be your interpretation, although you then changed your mind and wrote that a 20A switch would be OK!I doubt that anyone does. However, it is certainly possible to interpret what is "actually written" in a way that would mean that such things were prohibited, even if that were not the intention.
