I am having a pitched roof single storey extension along the length of the back of my house and I want to install a heat pump air conditioner. I am going to ask the architect to specify a continuous cavity along the length of the wall to hide the pipe work. I have read that the hole to the outside is usually 7cm so does that mean I would need a 7cm deep cavity to hold the pipework or is the standard UK stud depth of about 3.5cm OK?
And the other question is I need a 16amp circuit to power it but does the supply from the consumer unit go to the inside unit or the outside one?
