I'm currently in the process of installing some interior doors and corresponding frames in my house. The problem I am having is the width of the walls... The existing casings were 97mm wide to cover the studwork and plaster on either side, but the timber I have is 95mm, being the closest that was available. This obviously means that there will be a 2mm gap between the frame and the architrave running round the door, or 1mm if I spread the gap over both sides.
Can anyone suggest a solution to this? I have searched and it seems that 97mm width timber is not a common size. The house was built in the late 1970's.
Many thanks.
Many thanks.
