My upvc door seems to be coming loose at the top hinge. I tighten it with an allen key, to pull the top of the door towards the hinge side which seems to last for a couple of days only for it to become loose again, and then starts catching on the frame and creating friction on the frame.
What I've noticed is that when I turn the allen key, it gets to a point where the hinge gap is closest - if I keep rotating, it then loosens up again. I seem to be able to keep rotating in the same direction, it never tightens like a normal screw - I think this is by design?
It's hard for me to search what the problem is because I don't know what these hinge types are called - I can't find anything on the web that looks similar in design, so hopefully these pictures will help.
This photo is the problematic hinge with the gap, see how the allen key nut sits in the middle of the hinge.
Compared with the middle hinge, where the gap is much narrower and the allen key nut sits to the right side away from the hinge gap (this one doesn't cause any problems).
Side view of the hinge with a screw in the middle - not sure what this is for?
Any help would be much appreciated, thanks.
