I have a solid wood door that is really pretty but not the most insulated so I was going to have a go at making it a bit warmer.... I thought about the following 4 steps
1) Ive got a good brush setup to install and that should reducedraughts around the sides
2) Some parts of the door are quite thin (panelling), so I was considering sticking some insulation in the recesses, and then perhaps putting something over the bottom half of the door to level is up and give some benefit. I thought Kingspan might be a good option, but figured it would end up with loads of dents, is there something more durable/tougher? Needs to be lightweight I would guess too.
3) I have a few glass panels in the door that I could double glaze, but it would be a big job so I thought I would just stick some perspex over and do a DIY double glazing... (also its lighter than glass) I could even leave a hole at the bottom so I can put in some silica gel and try and keep condensation away... If it builds up again I can open the little hole and replace a little pouch of silica...
4) Ive also found an insulated internal letterbox that I think will work well (magflap).
Would love to hear your thoughts on materials and recommendations.... Thanks in advance!
