Doorbell and Transformer Installation
3 Sep 2020
I am looking to install the Ring Doorbell Pro to my property that currently has no hard wired doorbell.
The easiest route for running cable seems to be from the lighting circuit in the loft, down the cavity, to my front door.
I believe i need 18 gauge cable for the doorbell to the transformer, but i'm assuming i cannot use that same 18 gauge between the light switch to the transformer?
If not, what cable should i be using from the switch to the transformer?
Other than the cable, i'm assuming that everything else i am doing is an acceptable electrical process.
Any advice greatly recieved!
So 18 gauge, but double insulated?
Also, how do i know if the transformer need to be enclosed? The transformer was supplied with the Ring doorbell and is a DIN mounted type.
The Ring transformers I have seen for DIN-rail mounting DO require an enclosure. IIRC the enclosure needs to be 2-module, and these may be obtained from Screwfix, TLC, CEF and Toolstation among others. Search for "2-module DIN enclosure".
18 gauge by itself is meaningless. Could be 18SWG (standard wire gauge, a UK standard), or 18AWG (American wire gauge). They are different sizes.
Indeed, and although the former is about 1.17mm², the latter is only about 0.82mm².
Kind Regards, John
