- Joined
- 4 Feb 2004
- Messages
- 8
- Reaction score
- 0
- Country
When decorating stairs and hall in my flat, (I moved in about a year ago and I've just located my round tuit) I noticed there were two doorbell wires running down to the front door. One had been cut and was not connected to the doorbell switch.
I traced it back and it disappeared into the loft, where I found that it disappeared down into the cupboard at the top of the stairs, which holds my consumer unit. It disappears behind the consumer unit.
I decided that it wasn't necessary so I went to cut it, and all my lights went out, accompanied with a relay like buzzing sound. I let go of the cutters and the lights went back on.
I discovered that when the ends of the wire are shorted, the lights go out, which presumably would happen if the wire was connected into the doorbell switch.
I did a search on the net, and it seems this is a method to alert the deaf when the doorbell is being pushed.
Does anyone think this is what I have. It seems a bit crude, as the wire just disappears behind the consumer unit, and if all the lights are off, they don't come on when the wires are shorted, so you wouldn't know.
Would it be safe to get rid of?
