I'm replacing my doorbell as we are redecorating.
I'm moving the doorbell elsewhere also so it means running new wires.
Anyway it's a transformer wired outside the fuse box.
I got my multimeter out and when reading across the "8V" tapping I get 19V with the multimeter set to its lowest AC volt setting. If I connect the bell wire it's the same (obviously I suppose).
Is this within normal limits or is it a sign the transformer needs replacing. If so is this something I can do? (It looks straightforward, the bell is on its own MCB on the board and is isolated when this is turned off, confirmed by meter). All help appreciated, the bell works fine when connected by the way, don't know why I tested with the meter (just curious...)
Thanks.
Thanks.
