Dormer lead flashing
12 Jun 2020
Morning people,
Can’t see to find the recommend order to finish my dormer frame to get it water tight
So will have 12mm osb on frame
Breathable membrane
25mm batten for cavity
12mm render carrier board
10mm silicone render
I was going to lap the existing roof membrane up the dormer walls then wrap the dormer frame to overlap this.
Is it best to nail the lead flashing against the membrane or on to the battens. I’ve seen both ways done. Will be concrete interlocking tiles going down after.
I thought nailing against the membrane would be best as I believe the cavity should be vented top and bottom and going on top of the battens would close this?
Thank you!
You appear to be describing a cold roof approach in which case through ventilation is required,
Hi, it will be a cold roof above but I’m talking about the dormer walls which will have a 25mm battened cavity made off the timber osb frame
Morning people,
Breathable membrane
Thank you!
Really, the the lead needs to be more visible in case of future maintenance. That said, the bottom render bead will need to lap onto the lead in any case.
Roof membrane up the dormer, lead over this, dormer membrane over the lead, lead over or under the tiles depending on the tiles, render over the lead. Over and out.
Cheers. I was going to put the render bell cast bead on the STS boards in a horizontal line with the top of the lead flashing so it can be accessed. Is it still 150mm upstands on sides and front of dormers?
