I changed a double dimmer switch at the weekend after one of the sections, for quite some time, had ceased working on the old one.
Although the back of the new switch was different to the old one I managed to get the job done (sort of). There is a short piece of wire inside that runs from one terminal to another which I suspect is the one completing the circuit on the house extension (this is on another circuit to the main house). The thing works but I have discovered that sometimes, quite often actually, I have to hit the on button 3 times (consistently 3 when it happens) to get it to come on. This is with BOTH sets of lights as well.
The question is: have I somehow got the wiring wrong (in which case why does it come on at all)? Or could the new switch just be faulty? Please note that this happens less often if I remove the buttons and just push the plastic switches. Never seen anything quite like it before.
