Double electric oven to Double gas oven
6 Feb 2009
Lancashire
We are thinking of replacing our built in double electric oven to the stoves 900GDO gas double oven. At present there is no gas feed, we have a gas hob which is fitted rigidly with copper pipe, will the gas fitter be able to split the feed to supply the oven and the hob from the same pipe or will it require a totally separate feed. I don't want to purchase the oven if means taking apart my kitchen to lay a second copper pipe, I'll may just replace like for like
Andrew
It has a 15mm supply, so it will depend on what size pipe runs from your meter & what other gas appliances you have. Have you noticed that it is not suitable for instalation in flats( obviously I do not know whether this is applicable to you).
thanks for reply
It's as a 20mm pipe from the meter and the only other gas appliances in the house are the gas boiler and and gas fire in the lounge which never get used.
It does not matter whether appliances are used or not, but I think you will probably be ok & able to tee off the supply to the hob.
