Double glaze door in summerhouse.
15 Apr 2018
Hi All
I am building a summer house and have bought a some secondhand double glazed patio doors.
The frame of the summerhouse is made of 4X2 (95mm x 45mm) on the outside it has 11mm osb sheathing, tyvek, 25mm batten and finished off with 16mm (finished) cladding.
On the inside will jut be 16mm cladding.
So the total thickness of the wall is 163mm
I am not sure of the thickness of the door (70mm rings a bell) So I am unsure of where to fit it in relation to the wall, Flush to outside? Flush to inside? or in the middle?
Any thoughts are much appreciated.
The cladding is wooden tongue and groove.
No, not fitted the battens or cladding yet. Wanted to sort out the door 1st
All fitted now.
The door will be slightly recessed from the cladding but I will use edging trim to tidy/seal the "join"
Thanks all
