Hi, Thanks for your quick reply. Should I put the red COM to the other COM with the black wire? (Top right). Then L1 (Red) on one side and L2 (Black) on the other side ? Also , where should i connect the top center black wire to ? Should it e connected to the other L2? Thanks in advance for any help you can give.
