Double Pol switches......
3 Mar 2011
Yorkshire
Hi.... Can anyone assist please....
We have inadvertantly purchased double pol single switch light switches and wondered if there is any way these can be used in a room where we have 2 seperate single switches....
We have read the forum and know how to wire these into a room where there is only a single switch....
Any help or advice would be much appreciated....
If you have two switches which operate the same light i.e. a two way switching setup, then you can not use double pole switches as a replacement.
You can only use them to replace one way switches.
Many thanks for your prompt reply....
The way you describe is exactly our set up.....
Do you know what the switches are called that I need to swap them for please?
