You mean 'cheating'?There is a much simpler way: ....
Kind Regards, John
Good god, an electrician that can't do ohms law calculations. I must say that from most if your posts you are one of the last I'd have imagined that can't do simple sums.
Hang on, How is it easier to go on line than to use a calculator? Do you not know what apps are?Good god, an electrician that can't do ohms law calculations. I must say that from most if your posts you are one of the last I'd have imagined that can't do simple sums.
The moment I can't simple sums like Ohms law in my head is the day I hang up my screwdriver.
I've just tried to use this and it was more steps than using a calculator and less accurate. Probably fine for most domestic electrics calculations but rounding up or down at every stage then having to retype the rounded figure into another box for multiple stages of calculation is not for me.
Not really. It gives more results, more easily.I've just tried to use this and it was more steps than using a calculator
?and less accurate.
That was what you were doing.Probably fine for most domestic electrics calculations
Suit yourself.but rounding up or down at every stage then having to retype the rounded figure into another box for multiple stages of calculation is not for me.
For goodness sake SUNRAY your comments are getting sillier by the post.
Being good at maths does not prevent people using a calculator.
Sorry, I had assumed you were on line when you posted.
You did this in your head, did you?
"R=V²/W, 220²/3000=16.133Ω then I=V/R, 242/16.133=15A"
242/16.133 is a bit harder but a first approximation of 240/16 or 30/2 or 15 is a good starting point
And he's started arguing with himself:For goodness sake SUNRAY your comments are getting sillier by the post.
Maybe not, but it is perfectly compliant if the nature of the load is such that overloads cannot occur.As I've mentioned earlier, it would not occur to me to install a 2.5mm radial using a 32A OCD
Ah.Yes I did use a calculator for these calculations.
It's all becoming clearer.And yes I was on line when I posted but not when I had my head down the back of a washing machine.
Yes, that all looks very quick.But 220² is easy, going back to my schooldays times table thats 11²x4 plus a couple of zeros or 11 11's are 121, x4 = 484 +00 then /3000 comes down to 484/3 well back to times tables 48/3 =16 and 4/3 = 1 1/3 or 1333333333333333333333 (how many decimal places are required here?)
Until then it's very basic times tables junior school stuff, 242/16.133 is a bit harder but a first approximation of 240/16 or 30/2 or 15 is a good starting point. again it's just basic junior school times table stuff.
Silly or not I'd have got to that quicker than firing up the internet, typing in the first set of numbers then retyping the result and the new voltage.
I shall try to do better and stop making life easier.Yes I know my basic number crunching skills are good as they have been honed over the years in my day work and my hobbies. I wouldn't expect the same to be true for all but I do expect electricians to know the Ohms law triangle and power triangle without having to think about them without having to resort to the internet.
No BAS I'm not arguing with myself, perhaps I need to take a leaf out of your book and use more bold or bigger or coloured fonts to emphasise salient points.And he's started arguing with himself:
