Down-lighter transformer melted! Fire Hazard?!
27 Nov 2010
London
One of the downlighters in the kitchen has been coming on and off for a while. After a few weeks I changed the bulb, but it continued to do it. Today I finally got up there to pull the transformer out (each one has an individual transformer) and look what I found! Is this cheap chinese crap or what? Are they all 'at risk' of doing this? Presumably this could have caused a fire.
Haven't checked all the others yet (there are 12). Installed and signed off by a proper electrician when we had the kitchen extension done 3 & 1/2 years ago...
Any recommendations as to what make to buy to replace? One from this page or elsewhere? So much for all that CE nonsense printed on the damn box :x
http://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Transformers/index.html
Looks to me as if the transformer has been resting on the luminaire carcass - doesn't look like an internal fault.
Regards
hmmm maybe. It was pushed quite far inside the void though.I will check more closely.
I agree, its just been too close to the lamp.
Mind you, that taped up joint isn't kosher. It should be in a chocbox at the very least http://www.screwfix.com/p/chocbox/46538?_requestid=1713679
Would be a good idea to buy a bunch of choc boxes, take out each downlight, fit a chocbox and check that the transformer is away from the lamp.
EDIT
Looking again at your pic, it looks like you have a double-layered plasterboard ceiling. Is that a fire-rated ceiling? If it is then you need fire-rated downlights, those don't look fire-rated to me.
Looking at the picture the lamp leads look too short for the transformer burnt bit to have been laying on the lamp too me, i may have thought the wired end could.
How longs the lamp lead.
