- Joined
- 6 Aug 2020
- Messages
- 48
- Reaction score
- 0
- Country
Yeh sure I’ll take it back apart and post a picture shortly; better to be safe than sorry.Can you pull one out and take a photo? They need a longer length of exposed copper than you might expect, hence not being retained properly. You shouldnt be able to pull them out easily.It may be that you need to strip a little more.
You also need to sleeve the earth:
Is there a junction box that’s very similar but you have 6 screws for the 6 wires instead of three levers? Would be so much easier if you could secure each wire as you go along. With one lever controlling both openings makes it very fiddly.
Any tips on using the one in the link would be appreciated. For instance, is it better to put two of the same type in or is it better to secure each 3 core in turn?
