As above. Your basic problem is that you seem to have two lengths of (is it 1.5mm?) T&E on the terminal box.
The stiffness of the cable is pulling the light out of square.
Just try fitting one DL with no cables attached. If it fits properly then the cables are the problem.
you’ll need to terminate those chunky cables in another JB and just run a single bit of thinnish flex to the DLs.
