If it was asticking micro switch the boiler and pump would constantly fire but the downstairs circuit wouldnt heat up, if you want to test the micro switches, you need to open the wiring centre , with power off check for continuity, there will be 3 orange wires into the same terminal and 3 grey wires into another terminal, if you get continuity between the two terminals you will have to split them into individual pairs to see which pair has continuity
