DPC level when outisde ground is uneven
  • Thread starter Thread starter ESA
  • Start date Start date
ESA
16 Jan 2007
I am installing Dryzone this weekend and the ground that runs to the back of my house is higher than the ground to the front.
at the front of this house, 150mm off the ground is 2 courses of brick, but at the back it is 2.5 courses of brick.
My question is - If I start DPC installation from the front do I follow the mortar course up to remain 150mm above gound or do I install DPC cream 2 courses up at the front and 1.5 courses up at the back ?????
The important point to remember when using Dryzone is that it won't be confined to the level it's injected. It will give a nominal spread of 50mm above the injection point and 100mm below the injection point. I'd go for the higher injection point to help prevent against rainsplash. It would be fine injected 3 courses above ground level.
